AlanJ
NX1P2 to Indusoft communication
6 posts in this topic
How do I communicate between an Omron NX1P2 Automation Controller and Indusoft Web Studio. This is the first time using an Automation Controller. I am familiar with communicating between Omron PLC's and Indusoft using OMETH drivers. What driver should I use?
NX1P2 should use EtherNet/IP just like the NJ CPUs.  OMETH is for the older CJ/CS Series and FINS Ethernet.
Old post I know, but the Sysmac series of PLC's support FINS as well, so the OMETH driver should work but does not.
I am currently trying to get this to work, but returns error code 64-UDP/IP Receive call returned error
So, the question is: why is this, or what driver works with this series of PLC .?
I have an InTouch DASOMFINSEnet driver working to a NX1P2 with no issues, which is pretty much FINS
@lostcontrol
Cannot really guess why, since I believe the error 64 is not a FINS specified error.
Typically we debug FINS protocol error using MRES / SRES information returned by the master unit when the error occurred. It you can find that info from Indusoft, that'll be helpful.
The product is now InTouch Machine Edition, by Schneider/Aveva...
The only results that cousin google has for indusoft-NJ/NX is to use Sysmac gateway or componet ( I think )
What is odd, is that FINS is FINS, so it should work. Only the Indusoft driver developer will be able to say why it is not working...
Update:
Have now managed to get this working. There is a setting called 'Ignore non-fatal error' or similar, that defaults to No. Changing to yes enabled the basic FINS to work.
Edited by lostcontrol
Hello Folks,
Just to let you know that, in order to make the OMETH driver work with a NJ PLC, you should configure the Station field in the advanced driver settings.
On this field, put the FINS Network ID and the PC's ID that you want to assign, for instance 0:123
Check the page number 8 of the OMETH driver manual for further information.
