alpha91
Convert decimal to hex manually
9 posts in this topic
Dear all, did anyone did this before.
Actually I require to store the weighing reading in hex in order for SCADA to read. But now the weighing value is in decimal format.
For example:
Indicator display 1234 KG
suppose I need to store this value in 1234(hex) in data register, but now is 1234(decimal).
Does anyone here know how to do it? or can i do it manually? i have no idea on how to convert it.
On 4/21/2017 at 9:29 PM, kaiser_will said:
Decimal = 1234 kg
Hex => 1234/16 = 77 plus remainder of 2; next...77/16 = 4 plus remainder 13 (which is D); next...4/16 = 0 plus remainder 4.  Thusly, Decimal 1234 = Hex 4D2
http://www.rapidtables.com/convert/number/decimal-to-hex.htm
http://www.permadi.com/tutorial/numDecToHex/
Hi, yes, I got 4D2 when displaying in hex. But what i need is I need to show 1234kg in hex instead of 4D2.
Convert decimal number to BCD and display in Hex
1234 (decimal) =  0001001000110100 (BCD)
0001001000110100 (BCD) displayed in HEX format = 1234(hex)
Edited by Moggie
Hi, thank you very much for your help.
But i found that there is no function block in my Panasonic PLC can perform this function.
So is that means i need to do it manually, for example, write a calculation function for this conversion? or is there any better way to do this?
What model PLC are you using - or look at P80(BCD) / P82(DBCD)
Hi, it works! with the P80. Thank you very much.
May I know what is happening for this function? Sorry that i rarely do data conversion. I just roughly get the concept.
Is it the current decimal i reading now is BCD?
9 hours ago, panic mode said:
Hi, thank you very much for the manual.
