Posted 30 Jun 2016 I have a mitsubishi software programme in PCD file format and wanted to open the programme with GX Developer but couldnt open. Any one with an idea, help please Share this post Link to post Share on other sites
Posted 30 Jun 2016 A PCD is a GX IEC Developer backup file. You can't open this with GX Developer. You will need to get GX IEC Developer Share this post Link to post Share on other sites
Posted 5 Jul 2016 On Thursday, June 30, 2016 at 1:55 PM, Gambit said: A PCD is a GX IEC Developer backup file. You can't open this with GX Developer. You will need to get GX IEC Developer ok but what is the difference between the IEC developer and the GX developer Share this post Link to post Share on other sites
Posted 5 Jul 2016 With IEC Developer you can program via the IEC standard (europe). GX Developer is standard programming. Both these packages have been integrated into one GX Woks 2 Share this post Link to post Share on other sites
Posted 9 Jul 2016 On Tuesday, July 05, 2016 at 11:49 AM, Gambit said: With IEC Developer you can program via the IEC standard (europe). GX Developer is standard programming. Both these packages have been integrated into one GX Woks 2 Many thanks, but currently i have GX works 2 also but cannot find IEC developer, i found GX developer instead please what could be the problem since you said both are integrated in the GX works 2 Share this post Link to post Share on other sites
Posted 11 Jul 2016 You will only be able to open a GX IEC Developer project in GX Works if it is for an System Q. If it's an old A series you will have to use GX IEC Developer Share this post Link to post Share on other sites
