Posted 21 Jan 2015 I need disconnect for panel supplied with 120VAC power. I was hoping to find rotary disconnect with two poles (1 for hot, the other one for neutral) to run the incoming wires through but so far no luck, all I can find are the usual 3 and 4 pole disconnects. I guess I can use 1 pole 30A breaker and connect the neutral directly to the distribution block but I thought I could have disconnect with shaft/handle going through the front panel opening. Do they even exist? After I have spend couple hours looking for them with no luck I wonder if the breaker route is my only choice. Thanks. Share this post Link to post Share on other sites
Posted 21 Jan 2015 I just use a three-pole rotary disconnect. You don't have to use all three poles. Share this post Link to post Share on other sites
Posted 23 Jan 2015 I also use a three-pole rotary disconnect. They are fairly inexpensive if you get a non-fused type. Share this post Link to post Share on other sites
Posted 27 Jan 2015 Why break the neutral? It is not required. If you do break it then make sure you don't use a fused disconnect. 1 person likes this Share this post Link to post Share on other sites
