Posted 21 Jul 2006 I am working on a machine where scan time affects my process. I want to know that memory flags such as M0 are refreshed at the end of program scan or it is updated as soon as logic processing? Share this post Link to post Share on other sites
Posted 21 Jul 2006 The M coils are are direct refreshing. As the update as soon as the PLC scans the rung and does not wait till the end of the scan. The X and Ys wait till the end of the scan until they are updated. Share this post Link to post Share on other sites
Posted 21 Jul 2006 The normal scan of a PLC is like follow; 1st read inputs 2nd program execution 3rd write outputs All other devices than inputs and outputs are directly updated when used in the program. Share this post Link to post Share on other sites
Posted 23 Jul 2006 An alternative would be to set your plc to a constant scan time. This way you should get the same results continuously. For FX set M8039 and set scan time duration in D8039. For Q Cpu use setup in GX Dev Share this post Link to post Share on other sites
