mmervenne
Error when trying to convert
I get an error when i mak a change to the program and then try to convert. it say's "Caution the PLC Control has changed. Make sure everything is safe and execute again. It may take several minutes for writing to complete. Dont write to the program from a plurality of place at the same time. Make sure the PLC Program and the Program to be converted match. OK? If I Choose Yes, GX Developer locks up and i need to reboot to recover I can convert on other programs just this one gives me issues. Any help is greatly appreciated. Mike
I noticed on the title bar of my ladder logic it says " LD(R Edit Mode)", while my other ones say "LD(Edit Mode)". How do i switch that mode?
In the Tools, Options menu, change the Write During Run setting to Do Not Write To PLC if you're not doing online edits. The software asks you to change this setting to Write During Run when you perform online edits, but then is not smart enough to change it back when you're offline.
