PLCer
Error with C200-CT001
My friend is having 2 identical systems, each having a C200HE-CPU11 and a C200-CT001. He copies the program from a CPU to the other. But currently one of C200-CT001 unit has error with the Error lights. If he brings this C200-CT001 unit to the good CPU system, it is OK. if he brings the CPU with error to the good C200-CT001 unit, it has Error. Can any one give me an advice? Many thanks.
You will also need to make a copy of the Data Memories from where the CT001 gets its setup.
as upper said,the CT001 setting words are on DM area,you should copy them to the new PLC.and you should creative the I/O table
Thanks. I traced it from the IR mem to find that it's DM error. Fixed it! Thanks.
