2 posts in this topic
hi
have a good time
i have a nx102-1200 and a nx-ecs212 module.
I connected an SSI encoder to the card and read the position value in the software.
The encoder counts 360 pulses in each round and then it goes to zero.
I want to use GearIn function and have the encoder as the master and a servo motor as the slave.
In each revolution, the encoder pulse becomes zero, and as a result, the servo motor movement is not continuous!!!
I want the servo motor to be continuous! In fact, I don't want the encoder pulse to zero every time.
What should I do? Is there a solution?
please help me
thank you so much
Edited by hamid-tehranplc
How do you have the encoder axis setup in your Axis Settings?
