Posted 18 Nov 2023 Hi All, I have a problem, below END ladder still having continuous ladder . What it may cause ? And is it possible to check date/time of last online change from ladder program via GXWork3. Thank you Share this post Link to post Share on other sites
Posted 20 Nov 2023 you can pull the file last modified date from the pc itself. depending how your system is setup, you might find some previous files info under the right-click menu. Share this post Link to post Share on other sites
