Posted 28 Sep 2023 (edited) Hi all, I'm working on my migration from CJ series to Sysmac (NJ/NX). I've encountered something I think is a simple answer but I just can't find anything in the documentation or forums that has gave me a concrete answer. I want to increment a variable by one. Is it not possible to insert a raw integer into the value field of the function? (Please ignore the P_Off as this is only for test purposes only) I know I can create a variable and make it a constant of one but that just seems odd to have to go through that many steps to do so. EDIT: I should add the variable I'm trying to increment is a UINT (Unsigned Integer) The error I get is: Quote Error 1 Comparison, assignment, or operation is performed for different data types. Program0 Data Row 4 EDIT2: While I solved my problem with this instance by using the Increment function, my root question still remains. How do you supply a value of a number to a parameter of a function without creating a symbol for that parameter? Thank you all for your time, Edited 28 Sep 2023 by Red Share this post Link to post Share on other sites
Posted 28 Sep 2023 Hi, In Sysmac Studio in Ladder You have to assign type in constant value ("Type#Value"). For example UINT#1 or DINT#2 etc. 1 person likes this Share this post Link to post Share on other sites
Posted 28 Sep 2023 1 minute ago, realisator said: Hi, In Sysmac Studio in Ladder You have to assign type in constant value ("Type#Value"). For example UINT#1 or DINT#2 etc. Ah! I see. I saw that listed in the manual but I didn't take it as literal. Thank you kindly for that clarification! Share this post Link to post Share on other sites
Posted 29 Sep 2023 DATA TYPE # VALUE Int#1 REAL#3.14 This is the IEC standard designation for literals. 1 person likes this Share this post Link to post Share on other sites
