Posted 8 Mar 2022 Hi.. I have a problem with my analog CP1W AD041, it's reading value always "0". Can someone help me to configure software setting? I use PLC CP1E-N60SDT-D Thank you Share this post Link to post Share on other sites
Posted 19 Mar 2022 Hello Muahmmad, I have seen your post just now. May be it can be useful for yout to check out my recent reply in this forum about a similar subject. Share this post Link to post Share on other sites
Posted 23 Mar 2022 i use PLC input address CIO 000, CIO 001 and CIO 002, so CP1W-AD041 address should be start from CIO 003 right? Share this post Link to post Share on other sites
Posted 23 Mar 2022 here is my program reading 1-5 v analog input Share this post Link to post Share on other sites
Posted 23 Mar 2022 (edited) hello Muhammed,the ladder seems fine to me so it is tricky, however may be there is wiring issue or may be the PLC is confused about Expansion AI CH you effectively are using: i.e. if you are using only CIO3 you may try to inform the PLC about this fact like below: MOV #800E 103 MOV #8000 104 You may also recall expansion error word A436 and see if there is an error there I hope it helps Edited 23 Mar 2022 by suresh_ Share this post Link to post Share on other sites
Posted 23 Mar 2022 Okay, Mr Suresh, i'll try your sugestion Thanks a lot Share this post Link to post Share on other sites
