Posted 28 Jan 2022 I am having problem working with Mitsubishi FX5 PLC. How to send two bytes data into one word. I want to send first byte into lower word and second byte into upper word. Share this post Link to post Share on other sites
Posted 28 Jan 2022 the same way you would do that with digits in a decimal system. if you want 3 and 8 to become 38, you multiply first one by ten then add the second one. in case of 8-bit, you multiply first one by 256 or simply shift it left 8 places then add or OR result with the second byte. Share this post Link to post Share on other sites
Posted 28 Jan 2022 instead of shifting the bits you can use the swap instruction 1.) MOV HighByteValue D1 // move the High-Byte to D1 (this will be stored in the lower 8 Bit of D1) 2.) SWAP D1 // swap Hi/Lo of D1 (High-Byte-Value will stored in the upper 8 Bit of D1) 3.) WOR LowByteValue D1 // OR the value of the Low-Byte of D1 Share this post Link to post Share on other sites
Posted 28 Jan 2022 yup, that will work too. as usual there are many ways to get the same result. on a side note - without knowing where the data comes from and what the result is used for, i would just suggest some caution with data manipulation. you may want to check or ensure that "byte values are indeed only 8 bits or you may get surprise result. if the byte values are from some bitwise memory like I/O or M, you can use form that only takes 8 bits (for example K2M100). if the byte values are stored in D registers you may want to clear higher bits.. for example WAND HFF HighByteValue HighByteValue WAND HFF LowByteValue LowByteValue Share this post Link to post Share on other sites
