Posted 24 Nov 2021 Hi team; I am struggling with a Citect SCADA read of some data. The system is using the "Modnet3" driver over TCP/IP to talk with a system (Modnet 3 as its TCP/IP with first register at 0 and 0 to 15 bits). I am reading the modbus data into variables which is working fine for the analogue values all defined as real in citect. The Issue I have is that the driver help says I can direct reference a bit in a word, in my case address 45052.1 Holding register 45052 and Bit 1. If I read this as a UINT I get a value of 147 corresponding to bits 1,2,5 and 8. Citect generates no errors for the tag setup where I define 45052.0 through 45052.15 but all remain as zero in tag lists. Any help would be fantastic Kindest Regards Howard Share this post Link to post Share on other sites
Posted 12 Dec 2021 @hmwright Could you change data type to DIGITAL? Share this post Link to post Share on other sites
Posted 14 Dec 2021 Hi Wasan; thanks for your input, yes when using the 45052.0 through 45052.15 format the signals were assigned as Digital. Share this post Link to post Share on other sites
Posted 26 Dec 2021 Hi @hmwright I have create test project for MODNET3 bit in word.I have found that bit order on wor device is seperate into 2 block. I will describe below. 1. Create project with I/O Device to use Modnet3 (If necessary assign device address). 2. Create Variable tag with word and bit in word (For Modnet3 address start from 0 and have bit 0 - 15 that means in you need to read device that start address are 400001 you should assign in citect as 400000). 3. Compile and run project when assign word value is 147 then bit 8, 11, 14, 15 are on. 4. That because in Modbus data is arrange data from bit 16 to bit 1 5. If you need to start with bit 1 you should config parameter [MODNET]RegisterBitReverse from 0 to 1. 6. Select Setup Editor to edit Citect parameter. 7. Add Section MODNET then edit parameter as shown below then click "Add" button. 8. Go to File -> Save to save parameter. 9. Then Reload parameter and close window screen. 10. When run project again for value 147 bit 0, 1, 4 and7 will on. Share this post Link to post Share on other sites
