marfyll
INDUSOFT - VLC stream video RTSP
5 posts in this topic
Hello Guys,
Im trying to stream camera in indusoft thorigh vlc plugin (Activex), I want to use RTSP to stream, we have the URL rdy, but dont know where to insert
Someone tried this before, rly need assitance.
THANKS!!!
If speaking of VLC, I can say, In the phone app it is under networks and network stream, for PC based versions it's usually on the file menu and open stream or something like that,
Thanks for reply,
i know that, but this is using ActiveX plugin IN scada system Indusoft. (not just open VLC program and use the rtsp protocol)
I have no experience with the ActiveX but I would think Network Stream URL should be an editable property of the ocx if it's designed logically.
I don't know Indusoft but I do know most IP Camera's that support RTSP use port 554 as typical default,so: http://IP address:554 when you find where to put it.  Also Chrome web browser with IE tab extension, I think can view this so you could probably test url, IE tab extension for chrome can handle the active x, that's what i used to setup my camera's before doing the setup in other apps
Good luck
Edited by akahammer
