Boushard
M221C40R + TM3AQ2 analog output
4 posts in this topic
Hi guys,
I'm in another project with another brand on PLC and this time I thick I hit a pretty solid wall.
Long story short, I need to change a -10 +10v signal send to a DC motor drive based on a "recipe" selected with a 10 positions camswitch.
I've never programmed schneider PLC, except the zélio one who are pretty simple to understand.
Apparently Modicon are much more complex to program with the knowledge I have.
Is there documentation available somewhere I can use to understand how to code analog output.
The tm221 uses somachine basic which is not a complicated software.
With the little bit of info available I would just write a different value to the analog output depending on the cam position, and I would do it via operator blocks
I tried to paste some pictures but website doesnt allow it for some reason
Thanks for your answer cHud, but I have not a single clue how to make this.
This is why I ask for documentation about how to program it.
I'm use to program in ladder in Mitsubishi PLC.  Modicon are a little bit more tricky at first look!
