juancrangel
ErrorPV550
2 posts in this topic
Dear friends, I have a problem with panelview 550, I have an error "Comms Error = 13" as I can correct this or in where I can to obtain information of the errors of panelview 550 to part of the pagina www.ab.com since I do not have the communication with rslinx and I cannot see it. Thank you.
"Error 13 indicates: Bus-off interrupt occurred. CAN chip is held in reset. Caused by noise on network signal lines or an attempt to connect to the network at the wrong baud rate." Recommended Action: "Check baud rate and network wiring, including termination resistors. Reset the terminal."
