Posted 20 Feb 2017 (edited) Hi, Currently, I do have redundancy CITECT SCADA. On my primary server, it was able to send & receive data via using EGX100. Unfortunately, my secondary server was unable to do so if primary server is ON. Any possible solution that make both of my servers to send & receive data via using EGX100? Thank You. Edited 20 Feb 2017 by JS Share this post Link to post Share on other sites
Posted 20 Feb 2017 Hi! What do you mean by two server, two supervisior system? What PLC CPU are you using? If you set the primary server as Master and PLC as Slave, how did you set up the secondary server? may have an conflit.. Share this post Link to post Share on other sites
Posted 20 Feb 2017 Just now, Wesley said: Hi! What do you mean by two server, two supervisior system? What PLC CPU are you using? If you set the primary server as Master and PLC as Slave, how did you set up the secondary server? may have an conflit.. Good Day!, Primary Server was obtaining data via using Matrikon OPC Server. Those data were able to transfer from Primary Server via Modbus RS232 to another place after the mapping / calculation from CICODE but Secondary Server was not able to do so. So, is it the limitation of redundancy feature which caused CICODE ONLY run in Primary? Share this post Link to post Share on other sites
Posted 20 Feb 2017 I don't have great expertise in CICODE, but I don't know if it's the case but try to set secondary as slave as well. Share this post Link to post Share on other sites
Posted 21 Feb 2017 17 hours ago, Wesley said: I don't have great expertise in CICODE, but I don't know if it's the case but try to set secondary as slave as well. I did changed SECONDARY as MODBUS Slave but it still unworkable. Share this post Link to post Share on other sites
