Posted 19 Jan 2014 Anyone used serial IP converter to talk to Omron PLC. I need to add several C200HE to a network and an ethernet card is not available as far as I'm aware for this older PLC so I thought about using serial to ip converters at each plc. I've used serial ip software in the past to connect to Mitsi plc via ethernet connected HMI but gosh it was slow to do just about anything and don't want the same with serial ip comms. Any advice would be appreciated on serial ip make and model or any other ideas to achieve remote comms over network. Craig Share this post Link to post Share on other sites
Posted 23 Jan 2014 There was Ethernet cards for those, but since the entire platform is several generations obsolete, good luck finding one. Share this post Link to post Share on other sites
Posted 5 May 2014 Not sure about the challenge, but I've used MOXA 3170's for this issue with some older stuff I was trying to get to work. Hope this helps Share this post Link to post Share on other sites
