Posted 22 Mar 2012 (edited) I have been dealing with a re-occurring problem with a 1747-ABS card in a 13 slot chassis with another 13 slot chassis interconnected to it.. The card is generating a E51 and L31 fault.. All cards have been visually inspected and swapped one at a time, both chassis backplanes have been changed, the ABS card itself has been changed and I am still getting this fault.. It will run for 2 days to 2 months to 5 seconds between occurances.. Any help out there to help troubleshoot this?? I currently have a new interconnect wire on order.. I am also wondering if the power supply for the second 13 slot chassis may be part of it (the second chassis contains nothing but analog I/O and the operating voltages are fed thru the backplane).. Does this sound feasible?? The first chassis (which the ABS card is housed in) has 7 or 8 Triac output cards in it as well as a couple AC input and a fast DC input card.. This is not a new application and has been running for 12 years.. I have had problems on and off for the past 2 years.. Any input would be greatly appreciated.. ABs tech support has proven useless once again.. Edited 22 Mar 2012 by qyfab1 Share this post Link to post Share on other sites
Posted 22 Mar 2012 I would try swapping the chassis power supplies. Share this post Link to post Share on other sites
