Posted 26 May 2011 Hi, I would like to use H2-CTRIO in one of my projects where I would like to control four servo motors with two H2-CTRIO's. I want to give Differential line driver input to the Servo Drives. I am using an Incremental encoder to input pulses to the H2-CTRIO. Can anyone suggest me how to give A,B and Z Differential line Driver Output (5VDC) to the H2-CTRIO? Also how to connect the Servo Drivers to the H2-CTRIO for Differential line Driver Output? Because I haven't seen 5VDC input to the H2-CTRIO? Can H2-CTRIO generate an Output of 500K Pulses ? If any one has suggestions please reply anything that you know as I am using H2-CTRIO for the first time. Share this post Link to post Share on other sites
Posted 27 May 2011 (edited) Most of what you are asking is in the manual, which is available online for free at Automationdirect.com. Edited 27 May 2011 by rlp122 Share this post Link to post Share on other sites
Posted 1 Jun 2011 Thank you for your reply. As suggested by you I will go through the manual first then i will get back if any doubts. Share this post Link to post Share on other sites
