Posted 18 Oct 2010 I use the RSlogix 500 software as a newer of that now. But I have one question of using the software. Whenever I search the I:2.8/2 the result is so strange. That is always seen as I:2/130. So it is so difficult to search and debug the program source. How can I exchange the seen number as I want to see? For your more understanding I attach the captured picture. Thanks for your helping and advice. Share this post Link to post Share on other sites
Posted 18 Oct 2010 I:2.8/2 ==> 8 times 16 plus 2 is 130 Go to View/Properties Click on the Address Display tab Under I/O Bit Display Mode, select Slot.Word/Bit Click Apply You should be all set Share this post Link to post Share on other sites
Posted 18 Oct 2010 While you are at it, you may want to select single line for bit address display format instead of split line, that way the bit will display behind the solidus character (/) in the word address instead of displaying below. Share this post Link to post Share on other sites
