Bill
V400 Scanner to Mitsubishi QO2 Plc
2 posts in this topic
Greetings to all. I am new here. Hoping to get some help getting DOT MATRIX scanned numbers into plc program so I can determine that the number is correct and on the correct part. The DIRT: PLC: Mitsubishi: QO2CPU Scanner: Omron: V400-F350 Communication Card: QJ71C24N-R2 Currently I have the Scanner sending a "OK" signal if the DM tag is readable (Customer requirement). Now the powers that be want me to actually read the numbers and verify that they are on the right part. I need to somehow get the numbers from the DM tag into the PLC program so I can compare numbers and match up to a RH or LH part. I know this is clear as mud but I am trying to get the ball rolling. Any help would be greatly appreciated.
A really quick look at the manual for the V400 seems to indicate you will need to modify the setup of the unit. It appears that currently it is configured to output if the code is readable. You will need to modify the setup to output the data string. Hope this will help.
