Posted 5 Aug 2010 Hi Everyone, I want to connect between Mitsubishi and Allen Bradley using Modbus Protocol. in Mitsubishi PLC, i use AJ71UC24-S2 as a slave. what confusing me was, how to initiate command and sent command in Mitsubishi PLC? like usually in modbus protocol when want to read register we use function code 3. and how to define data tag to modbus address? Thanks. Share this post Link to post Share on other sites
Posted 5 Aug 2010 Hi. As long as you are a slave in the Mitsubishi you don't need to "send" any data. The module will automaticly generate the correct response when a request is received. The devices in the Mitsubishi CPU are allocated to specific Modbus devices, take a look in the manual under chapter 6.4 (Device Allocations). Share this post Link to post Share on other sites
