panic mode
[PLC Sample Code] - SLC500 Measure Resistance
1 post in this topic
File Name: SLC500 Measure Resistance File Submitter: panic mode File Submitted: 28 Dec 2006 File Category: PLC Sample Code This was one of my early projects. I had to measure resistance in pretty wide range on a delicate circuit (subject was changing value and in range from few ohms to more than 1MOhm). Normally I would have used something like RTD transducer but I just couldn't find anything suitable for that range (every transducer I could find was stopping at some 8 or 10k i needed at least 100x more). The time was running out so I had to put something together and fast. This is it. Initially this circuit was using dedicated regulated low voltage power supply but since I had spare analog input(s) I replaced that power supply with voltage divider (Panel had existing 24VDC power supply) and simply had to monitor that voltage because it was not regulated any more (the 24VDC was regulated but the output of divider was changing depending on test conditions). Although we like to avoid custom designs this turned out to be so simple cheap easy to use and worked extremly well. It is so small that there was no need for PCB two resistors ware connected directly to terminals. Accuracy off course could not match the 8-digits of precission benchtop multimeter but it was on pair with my multimeters which is more than I could ask for. I didn't test it for significant ambient changes (temperature and humitity). There are several ways to do the math for this and in fact used aproach is not the simplest or most efficient. But it is good example on how simple DC circuits knowledge and very basic match can be used in practice. R1 and R2 are not critical and don't need to be accurate either (just need to produce voltage that fits selected range for used input card. It is robust enough. In fact I was surprised to see results when R1/R2 ratio was adjusted to produce only 1 Volt (what kind of ADC they have in their cards?). ----- EDIT ---- Download Link currently doesn't work so just click on "Click here for to join forum discussion" Click here to download this file
