Posted 10 May 2008 Hello All I have the following bit arrays declared Fire1 - M100 ARRAY [0-31] OF BOOL Fire2 - M132 ARRAY [0-31] OF BOOL I'm using the various bits in my program (FX1N) and would like to compare the all the bits for not equal to zero. I'm trying to DMOV_M the 32 bits of the array into VarD0 (D0 - 32bit) so I can compare the 32bits at in one go but the software doesn't like the input to DMOV_M. can someone help me out. I'm Using GX IEC Developer V7.01 regards Shamus Share this post Link to post Share on other sites
Posted 10 May 2008 Don't know about IEC version but this is how you check for non-zero value in 32-bit (8 nibbles) in standard GX [D<> K8M100 K0]----------------------(M200) // Fire1 [D<> K8M132 K0]----------------------(M201) // Fire2 If you are using MOV instruction: --| |-------------------------------[DMOV K8M100 D100] --| |-------------------------------[DMOV K8M132 D102] or for 16-bit (4 nibbles): --| |-------------------------------[DMOV K4M100 D100] --| |-------------------------------[DMOV K4M116 D101] --| |-------------------------------[DMOV K4M132 D102] --| |-------------------------------[DMOV K4M148 D103] Check user manual for GX Developer. Share this post Link to post Share on other sites
