* * * * * 1 votes
Simple programming cable for Mitsubishi FX
  • Please log in to reply
88 replies to this topic
#1 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 31 May 2003 - 11:08 PM
So, here is a knife to the Beijers back- a simple and inexpensive programming cable for Mitsubishi FX series, to be used instead of SC-09.
The cable is successfully used with FX0N, FX1N, FX1S, FX2N.
EDIT: According to repeated complains this cable may not work with FX0, FX0S.
The connectors on the diagram are 8-pin mini-DIN male on the PLC side and 9-pin sub-D female on the PC side.
Take measures in order for the PLC pin 5 (+5V) not to be shorted with any other one in order to prevent the PLC or PC port damage.
For AC powered PLC, the requirement to avoid phase conflict by powering PC from the same AC phase remains in power, exactly as for the SC-09 cable.
The difference is that in a case of phase conflict at least cable is not damaged now.
Edited by Sergei Troizky, 21 March 2005 - 06:41 PM.
#2 Guest_Guest_*
Guest_Guest_*
  • Guest
Posted 01 June 2003 - 09:00 PM
you didn't keep the promise, you were 52 minutes too early :dance:
#3 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 02 June 2003 - 08:50 PM
I live in Montreal, Canada and here was after midnight already :-p
I always keep my promises.
Edited by Sergei Troizky, 02 June 2003 - 08:53 PM.
#4 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 12 July 2003 - 06:06 PM
Attention all users of the described cable.
Sometimes, with the FX1N-422-BD port duplicator card installed in FX1N, the cable does not work with one of the ports (more often- with the duplicator card port).
MEDOC is indicating "Error in received data", "PLC replies NAK", or simply communicates slow with lots of retries.
The cable still works perfectly with another port in such cases.
Edited by Sergei Troizky, 22 February 2004 - 03:55 PM.
#5 Guest_Scooter_*
Guest_Scooter_*
  • Guest
Posted 15 July 2003 - 03:05 AM
Has anyone tried this cable? (besides the inventor)\
If it works, A big :shrug: to Sergei.
#6 Guest_Ken_*
Guest_Ken_*
  • Guest
Posted 23 July 2003 - 11:03 AM
Can it be used with FX1GM as well? what's the program required to use FX1GM?
#7 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 23 July 2003 - 08:42 PM
The part number sounds like a motion controller but I've never heard of this specific one.
The FX2N-10GM/20-GM use the SC-09 cable, and my cable should work with them.
#8 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 25 July 2003 - 08:46 PM
The cable may be even simpler- replace the resistor with jumper.
Tested.
#9 Guest_Wouter_*
Guest_Wouter_*
  • Guest
Posted 17 September 2003 - 03:09 AM
Sergei are you sure that the cable won't do any damage to the PLC or PC? Because I don't want to blow up my precious PLC :*-(
Have other people test this cable already? Did it work?
Greetz :clap:
#10 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
  • Country:United States
    United States
Posted 17 September 2003 - 07:46 PM
Wouter:
I have one customer, who tested Sergey's cable with FX1N and it was working fine with 8pin port. It will not work with 25pin port.
I don't know about FX0 PLC you have.
It should not damage PC or PLC.
Just keep in mind that SC09 does not have any opto-isulation, only ESD protection.
If you handy, you can make your own SC09 cable as a good school project:
it takes only one or 2 ICs and few capacitors.
Beijers schematics is widely available and I have 5 or 6 different simplified schematic versions and it depends what chips you can get.
Email me, if you need more details.
micromet@adelphia.net
Alex
#11 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 17 September 2003 - 08:24 PM
Wouter,
The cable cannot damage PC or PLC port, assumung no mistakes in wiring.
I used it in tens of commercial projects already.
For more security leave the resistor in place: a wiring mistake with jumper can damage a port, with resistor- not.
With FX0 it may work even without jumper, but not guaranteed.
PLC Cables,
I do not understand whether you mean PLC or PC 25-pin port.
In any case I do not see a reason for the cable not to work (with corrected pin numbers in wiring, of course).
I also do not see any reason to clone SC-09 if a pin-to-pin cable makes the job.
Edited by Sergei Troizky, 21 September 2003 - 07:10 PM.
#12 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
    United States
Posted 17 September 2003 - 08:48 PM
Sergei,
I mean PLCs with 25 pin port - older style like A-series.
They are using handshaking lines RTS/CTS along with RXD/TXD.
It is possible to modify your cable to add this lines, but it will not work with 25pin port AS IS.
In any case it will not damage PLC or PC.
Nobody should copy SC09 desing, it can be simplified to minimum components or minimum cost.
But your cable definately works as a cheap programming alternative to SC09.
Just for some projects you must stay within RS422/R232 interface specification like min/max voltage, max distance etc. ESD protection also required.
Alex
#13 Guest_Ken_*
Guest_Ken_*
  • Guest
Posted 13 January 2004 - 12:20 PM
Hi guys. Can anybody tell me what software is used to program FX2n-10GM with this cable? Medoc possible?
thanks
#14 Guest_lansoc_*
Guest_lansoc_*
  • Guest
Posted 02 February 2004 - 11:36 AM
Hey, Sergei Troizky
Do you have any knowledge of the old MTA-10 "baby" op station build by Beijers and sold under the Mitsu name???
It uses a similar cable called an SC-06N which is used for download from a win based config program. It like the SC-09 is a 232-422 converter.
It has one hooker, 2 pins are also supplying +5vdc & "-" for powering it up. That's no problem.
I'm interested in the possiblity of using your cable in the same fashion. I'm worried about just giving it a try and end up damaging PC Port or MTA-10 port.
Any info would be appreciated. I have drawing of SC-06N it that would help you to help me!
I'm not an electronics person so the chips in the device are kind of way over my head!
THANX!
#15 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 05 February 2004 - 11:02 PM
Hi, Lansoc
The principle should work with MTA-10/12, but I have never tried.
And will not try already.
MTA is obsolete and, probably, discontinued product.
I have replaced it with Aromat GT-10 small touchscreen in my projects.
Sergei
#16 Guest_TROUBLED PLC MAN_*
  • Guest
Posted 17 February 2004 - 01:02 PM
Sergei,
I was wondering if you have any cabling ideas for the FX1n for laptops without serial ports. I purchased a USB to serial cable converter but it does not work with the PLC. ANy ideas???
MIKE :stupid:
#17 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
    United States
Posted 17 February 2004 - 06:03 PM
Look here: Shops at MRPLC
#18 Jimbo
Jimbo
    Sparky
  • MrPLC Member
  • PipPipPip
  • 32 posts
  • Interests:Skiing, Snooker, Drinking beer, Having fun, ...
Posted 18 February 2004 - 05:36 AM
In the beginning i had some problems with my usb to serial convertor and the mitsubishi programming software but i solved it with updating my windows XP to service pack 1. So i suggest you do a windows update
Greetz
#19 Guest_troubled PLC man_*
  • Guest
Posted 19 February 2004 - 09:14 AM
OK,
First, I have purchased a serial PCMCIA card per my local MITS rep suggestion. It has not arrived yet. I am running teh latest, most up to date version of XP.
I am using a Belkin converter with the SC09 cable to my FX1N PLC. The software being used is GX IEC Developer. I receive a communication error with the PLC even though all transmit settings are correct. I get a quick flask of teh lights on my adapter and then the error.
My local REP says that the converters are sometimes problems and that they use the PCMCIA cards. I will let you know how it works out with that card once I get to try it. I have to get it wokred out b4 my next road trip or I will have to bring two laptops with me :stupid:
MIke
#20 Guest_troubled plc man_*
  • Guest
Posted 19 February 2004 - 09:17 AM
THank you PLC CABLES, I wish I had seen that before I ordered the Card.
Mike
#21 Sergei Troizky
Sergei Troizky
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 625 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 19 February 2004 - 09:38 PM
Most probably, not all the communication settings are OK.
Also, I would test the converter with anything else.
A serial mouse is good enough, if you can get one.
Or try another brand PLC, with RS232 programming port.
SC-09 also should be tested on another PC with a serial port.
Edited by Sergei Troizky, 19 February 2004 - 09:40 PM.
#22 Guest_TROUBLED PLC MAN_*
  • Guest
Posted 26 February 2004 - 09:33 AM
UPDATE:
Received the new cable from MRPLC and it works great. no cards, no converters (except the one built into the cable).
Thanks again,
Mike :shrug:
#23 Guest_Henk_*
Guest_Henk_*
  • Guest
Posted 22 April 2004 - 02:35 PM
The cable is working fine on my FX10.
Thanks.
#24 Guest_Guest_mike_*
Guest_Guest_mike_*
  • Guest
Posted 10 May 2004 - 02:52 AM
I made cable as shown, but it doesn't work. Program Melsec Medox v1.1, FX0 logic. I get communication error. Any hints?`
Thanks.
#25 Guest_mkarvine_*
Guest_mkarvine_*
  • Guest
Posted 14 May 2004 - 04:32 PM
I still didn't get the cable to work :*-( but here's diagram that worked fine with me:
PLC / PC db-9
1____3
2____5
3____5
4____2
6____1,4,6
7____5
-short connect PC pins 7 and 8
-connect connectors "grounds?" together
Edited by mkarvine, 14 May 2004 - 04:33 PM.
#26 rajsiyer
rajsiyer
    Sparky
  • MrPLC Member
  • PipPipPip
  • 264 posts
  • Gender:Male
  • Location:704/83, Panchavati Bldg., Vasant Vihar, Pokhran Road-2, Thane. (near Mumbai)India pin:400610
  • Interests:AB,Schneider, Citect, HIMA, Siemens,Intouch, ABB, GEFanuc etc. A seasoned electrical engineer.
  • Country:India
    India
Posted 19 July 2004 - 08:40 AM
Hi folks..
Iíve a problem. Thereís a Mitsubishi FX2-32 and its hand held programmer with us. When linked together, they communicate fine. Only that the HHP screens are in Japanese.
Since Iíve also got Medoc v 2.3(DOS) Iíve tried to link the RS-422 port on the FX2 -32 with the pc using a MOXA /ADAM converter (Typ. ADAM 4520) using the RXD+, RXD -, TXD+ and TXD- (pins that are 2,15, 3 and16 on the 25-pin port connnector of the PLC). I have tried innumerable combinations of baud-rate, parity and data bits so that communication may be established. Nothing works.
So.. would somebody help me out with this. At least how could it be known at what comm.. settings parameters, the Hand held programmer talks.
Thanks a million..
Raj
My name is Raj. I live and work in my beloved country India, as head of projects, Prolific systems & Technologies Pvt. Ltd. I am primarily an electrical engineer from the College of Engineering Pune. (grad.1983). I look up to this site as friend philosopher and guide and always endeavor to help out my fellow automation engineers in any doubt.
#27 Guest_Guest_*
Guest_Guest_*
  • Guest
Posted 26 July 2004 - 11:35 AM
I used Sergei's simple cable on a 25 pin D Connector RS-422 port on a FX plc with only a small modification: And I'm happy to tell the world that it works very, very very well.
Connect the RXD enable pin(Pin 21) to ground. You need the RTS+ and RTS- signals too. Connect them to 0v and +5v, through a 1k resistor. and your cable is ready to communicate. A number of pins i.e. 12, 13, 25 carry the 5v Signal. Likewise the ground voltage is available at pins7 & 8.
The rest of the cable is exactly as described by sergei. The needed RXd and TXd negatives are led to cross connect at the PC with TX & RX. The ground voltage must be linked to pin 5 of the PC's port.
A big big thanks to Sergei once again,
RAJ S> IYER
#28 panic mode
panic mode
    Mitsubishi Moderator
  • MrPLC Admin
  • 2119 posts
  • Gender:Male
  • Interests:many...
  • Country:Canada
    Canada
Posted 26 July 2004 - 01:05 PM
Can you provide drawing?
#29 rajsiyer
rajsiyer
    Sparky
  • MrPLC Member
  • PipPipPip
  • 264 posts
  • Gender:Male
  • Country:India
    India
Posted 01 August 2004 - 11:06 AM
Here is the cable I made, it works well on both Round pin as well as 25 Pin connectors, if connected in the manner shown. Importantly, it is the RX Negative and TX negative signals that are cross connected with TD and RD on the PC. One may avoid using the 5 Volt signal at the mini Din Connector if no power is needed that end
Regards,
Raj
Attached File  CABLE.doc   67KB   14058 downloads
Edited by rajsiyer, 11 February 2006 - 05:13 AM.
#30 Guest_Guest_Wouter_*
  • Guest
Posted 14 August 2004 - 11:32 AM
Can anybody tell me the difference between a 250-300$ SC-09 cable and the 20 cent cable that has been posted on this forum? I want to try the simple cable posted by Sergei, but I want to make sure that my precious little PLC won't be hurt. :-1 What makes the original cable so expensive?
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
