Initialize PID(190)
  • Please log in to reply
2 replies to this topic
#1 aVi
aVi
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 1 posts
  • Country:United States
    United States
Posted 05 December 2010 - 10:28 AM
I'm working on integrating a PID for tension control into a CS1G-H processor. I have already been able to successfully implement this PID in a similar application with a Siemens 313C PLC using their integrated PID. So far I am optimistic but, Siemens has an Initialize integral action bit which presets the integral component of the PID when set. I have been unable to recreate this function in Omron's PID. Is such a function possible with PID(190)?
#2 Sleepy Wombat
Sleepy Wombat
    Controls Engineer
  • MrPLC Admin
  • 2000 posts
  • Gender:Male
  • Country:Australia
    Australia
Posted 10 December 2010 - 03:00 AM
You are using the H series - i thought that the PID instruction in this series plc had an auto tune function.
Anyways, I am a bit unclear as to what you mean by pre set the integral.
You can set the P I and D via the corresponding memory areas determined by your control word.
There is a setup bit that alows dynamic chaning of the P I and D values while the PID is executing, if you do not set this bit then the P I and D settings will only be initalised on the up of the enable signal line for the PID.
Remember to set a value for the T constant also.
DEXA Pty Ltd
Design Engineering Xtreme Automation
We have a NEW website... check it out at
www.dexa.com.au
#3 ParaffinPower
ParaffinPower
    Sparky
  • MrPLC Member
  • PipPipPip
  • 427 posts
  • Country:United Kingdom
    United Kingdom
Posted 13 December 2010 - 02:11 PM
Hi SW
I think the OP meant Reset, not Preset the integral. I've had a look, and can't find anything, I'm afraid. I guess one of the 30 or so Words the PID intruction uses is the integral portion of the output. I'll try to decode it next time I'm using it...
Edit:
Not sure here, but can you change the integral gain to 9999 (disabled); I don't know if the integral action will return to what it was or start at zero again when you re-instate the 'correct' I gain?
Pp
Edited by ParaffinPower, 13 December 2010 - 02:17 PM.
Download » CX-Programmer
    No categories found.
Store » CX-Programmer
Articles » CX-Programmer
