micrologix 1500 High speed counters
  • Please log in to reply
9 replies to this topic
#1 kewl1313
kewl1313
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 4 posts
  • Country:United States
    United States
Posted 01 September 2010 - 06:07 PM
I am trying to figure out how to setup and use the high speed counter. I am trying to us a encoder with it. Then us the encoder and a space counter...as per expamle x amout of encoder tic's make x amount of inches.. Any Help would be nice.
Thanks
Dan
#2 b_carlton
b_carlton
    User
  • MrPLC Member
  • PipPipPipPipPipPip
  • 1016 posts
  • Gender:Male
    United States
Posted 02 September 2010 - 06:25 AM
Do you have the encoder hooked up?
Do you see the input bit turn on and off as you rotate the encoder?
Are counts occurring in the HSC accumulator?
How far are you in this development? Where do you need help?
An output is a PLC's way of getting its inputs to change.
#3 kewl1313
kewl1313
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 4 posts
    United States
Posted 03 September 2010 - 07:37 AM
Yes I have it hooked up and I do get a signal. I do believe I need to fine tune my signal for it. I only get one count on 1 fulll turn. I can get the signal to go to a N7 file and watch it count. I am trying to figure out how to write the logic so I can use the signal to either make a funtcion start or stop. Thanks
#4 b_carlton
b_carlton
    User
  • MrPLC Member
  • 1016 posts
  • Gender:Male
    United States
Posted 03 September 2010 - 08:22 AM
Now that you have the count as a number look up the math instructions and compare instructions. You can manipulate the numbers and compare them to points a which you wish actions to be carried out.
#5 OkiePC
OkiePC
    Boat Rocker/Trouble Breaker
  • MrPLC Member
  • PipPipPipPipPip
  • 934 posts
  • Gender:Male
  • Interests:Kids, Outdoors, Animals, Sports, Science, Math, Music, Puzzles, Video Games, Food, Watersports, Paintball, Jeeps, Pit Bulldogs, Chevy, OU Football, Hiking, Piddling, more ...
    United States
Posted 03 September 2010 - 01:26 PM
That description makes it sound like you are only counting the z-pulse.
Can you tell us more about how the encoder is wired?
Be as specific as possible, and include part numbers if you can.
Edited by OkiePC, 03 September 2010 - 01:27 PM.
#6 blperkins
blperkins
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 2 posts
Posted 05 September 2010 - 07:21 PM
One more thing that always gets me. Is to set the filter time of the input down.
#7 kewl1313
kewl1313
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 4 posts
    United States
Posted 09 September 2010 - 06:51 AM
The encoder is one off of a machine that we used to have...It is a BEI IDEACOD type: GHM510-1800-001, I have wired up 24vdc out of the plc and wired up A which is a green wire and B which is a yellow wire.
A is hooked up to I:0 and B is hooked up to I:1. Hopes this helps... Thanks again veryone
#8 kaiser_will
kaiser_will
    Sparky
  • MrPLC Member
  • PipPipPip
  • 280 posts
    United States
Posted 09 September 2010 - 08:09 AM
You do not mention wiring up A- or B-. Don't leave the common of the channels floating.
The channels are wired into discrete inputs, or high-speed counter inputs?
If you have access to an oscilloscope, you should be able to tap into the pulse train from channels and verify a signal.
What PLC model and high speed counter card are you using?
#9 kewl1313
kewl1313
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 4 posts
    United States
Posted 09 September 2010 - 11:11 AM
I wired it up as per the Rockwell Automation. They did not say to wire up the A- or B-.... As for a oscilloscope I can not get one.
The PLC is a MicroLogix 1500 and I am using the High speed counter that is built in.. Which lets me us Input 0 and Input 1.
If there is a better way of doing this Please let me know..
#10 OkiePC
OkiePC
  • MrPLC Member
  • PipPipPipPipPip
  • 934 posts
  • Gender:Male
    United States
Posted 09 September 2010 - 11:45 AM
Not finding any info on your part number.
Sounds like you have it wired right.
The filter settings are going to be critical...be sure to check that under I/O config.
You need to use the HSC file, not just regular input instructions and counter. I have little experience with the function files in the Micrologix, but Bernie appears to have strong knowledge in setting that up.
