Posted 23 Feb 2006 GOODS I HAVE TO PLACE A SIEMMENS S7-300 IN COMMUNICATION WITH A SATT CONTROL VERSION "SATTCON15" BUT I DON´T NOW WICH IS THE COMMUNICATION TYPE. ANY ONE CAN HELP ??? IS THERE ANY INTERFACE? THANKS JORGE Share this post Link to post Share on other sites
Posted 24 Feb 2006 From my limited experience with Sattcontrols, you may be struggling. If I remember correctly, the Satt's will talk only one external protocol which is "COMLI", and I don't think that Siemens support this protocol. How much data do you want to exchange? If it's just several words or so, you may get away with using an HMI as a data exchange unit. An HMI such as the Mitsubishi / Beijers E100 is a good starting point, it is very cheap and has two serial ports which you can do data exchange through, use one port on the COMLI protocol and the other on the SIMATIC protocol Share this post Link to post Share on other sites
Posted 7 Mar 2006 Hello Where can I find info and specs about the software that programs the SattControl (DOX 10 if I´m correct), I am working with a SattControl unit and trying to understand the Program List..... any help would be great. Thanks in advance odreplc Share this post Link to post Share on other sites
