Posted 3 October Hi, to start, I'm very new to Siemens PLCs, but quite experienced on others (mainly ABB). I'm looking to set up a profinet network between an ABB AC500 PLC and an S7-1200. The goal is to transfer variables from an existing S7-1200 (owned by the customer) to my new AC500. It is required that I do this without having to stop the S7-1200. I can set up the AC500 as a profinet device, and have the S7-1200 remain as the controller, but this requires a config change on the S7-1200, which means I'd have to stop the PLC. I tried setting up the ABB as a profinet controller, but I'm having trouble finding a GSDML for the S7-1200 to allow me to do this. Can anyone advise me on the best route to take to solve this problem? Thanks in advance. Share this post Link to post Share on other sites
Posted 4 October (edited) I believe the I-Device (Profinet device) functionality of the S7-1200 is only available with firmware version V4.0 and higher. You would need to STOP the CPU, because the S7-1200 requires a hardware configuration change whether you use it as an IO-Controller, or IO-Device. Go into the S7-1200 CPU Ethernet port properties and select the checkbox "IO Device", and add input/output transfer areas as needed. Then right-click on your PLC and compile hardware and software (only changes). You'll need to download to the CPU, which will stop it - there's no way around this. Then you'll see below the "Transfer Areas" a button to export the GSDML file. Import this file into your ABB Profinet configuration. Another way is to buy a PN/PN Coupler, which allows 2 masters to exchange data. However, both methods will require the S7-1200 PLC to stop. Edited 4 October by sigmadelta 1 person likes this Share this post Link to post Share on other sites
