Posted 19 Mar 2018 Does anyone have an .eds file for the Zebra printers. I need to use ethernet/IP from a CJ2MCPU31 Share this post Link to post Share on other sites
Posted 20 Mar 2018 It doesn't appear they are Ethernet/IP compatible. Generally, the device manufacturers will distribute the EDS files if they are available. Share this post Link to post Share on other sites
Posted 20 Mar 2018 Checked it also, and as IO_Rack said it doesn't have Ethernet/IP capability. You can, however, use TCP/IP or more likely called as Socket Service TCP in Omron manuals. To bad though the CJ2M-CPU31 CPU unit does not support Socket Service. You need to purchase CJ1W-ETN21 module and plug it in to the CPU in order to have Socket Service capability. Another option is to use RS-232 serial (Z230 manual mentioned that it supports RS-232) which considerably cheaper since you just need to buy CJ1W-CIF01 option board to be plugged on the CJ2M-CPU31 CPU, granted that you haven't use it for other connection Share this post Link to post Share on other sites
