bagged2drag
TIA Portal V13 Assign Profinet Device name
2 posts in this topic
Hello,
I have a Siemens S7-300 using Tia Portal V13.   It is connected to an ANYBUS Communicater.   The Anybus configuration became corrupted.  I reset it per a conversation with a vendor.  I need to now reset the device name, as it has been cleared out.  The Siemens sets the device name according the the device properties.  Right now I get a fault that the anybus is not reachable.   Is there a way to reset the device name?
Kris
bagged2drag.
If you have the MAC-Address you can use the PST Too from Siemens Automation (Primary Set up tool). This is the tool I use to initially configure all nodes on my Profinet networks.
Confirm you have the correct MAC Address before applying an IP Address and node name.
If you have an issue with the AnyBus card- you may need to restore factory defaults before carrying out the method above.
