professor_jonny
cp1l modbus coms to danfos fc280 midi drive sample program
8 posts in this topic
Hi
I have adapted a sample cp1l function block Modbus program to talk to the new Danfoss fc280 midi drive.
It will read and write the standard FC control profile it would be easy to extend the pcd feature to multiple words all the base is there.
I have not implemented parameter writing and reading but it would be easy enough to extend it but for my application I don't see the need.
It may come in useful to someone as there does not seem to be much out in the wild and the Danfoss Modbus document is somewhat confusing and actually has incorrect data.
It was tested and setup with L series cpu
Modbus_Danfoss_fc280.cxp
Edited by professor_jonny
Hallo Jonny .
can the program also work with an CJ2M31 or 33 with a SCU42 MODBUS comminicating with the FC51 from Danfoss ?
Just now, Johanb said:
Hallo Jonny .
I'm prity sure you will need to modify to suit but I'm not sure really, this is more designed for the cp1 series easy Modbus master function blocks
all the hard part with the addresses and Modbus conversion has been done you just need to redirect the data to the scu42.
I have downloaded your prog , but I can not find the configuration for the FC280 .
or what kind of communication you use for the serial port ( ( protocol macro or serial  ).
I have now an prog running for the distance selction on an internal shooting range .
I use a Fc51 to drive a motor with revolution trigger and Home sensor ( connected to the FC51 .
the drive communicate by Modbus to a SCU42 card from OMRON .
all Data is read and controled through ethernet IP and a NS5 screen .
I have only some problem writing the start coil and changing some parameters .
that is why I would like to try out your prog .
regards johan
Init_setup contains the setup for the read and write register the target note and the amount of words you want to send/ receive.
The FC_port sections contain the control, status, main actual value and reference as set by default with the Modbus control word and is the default 2 read and write control words as defined in the danfoss drive Modbus manual.
I have broken the control word into output coils so it is real easy to run the drive just by setting bits all the magic is done in the function blocks and I'm guessing you will be able to use the base code for your cj2 plc and scrap the functionblocks.
Modbus_RTU section contains the read and write parameters you could translate to what ever serial port you wish to use currently they are setup using the Modbus easy master function blocks.
This program is aimed as the cheap brick plc's using the plug in cif11 option port the serial port settings are setup in the plc setup.
you could upgrade the drive to the fc280 or fc302 and use EithernetIP option card it makes more sence than using Modbus in your case.
my plc does not have EithernetIP or that is what I would use.
The point is I controle 15 shooting range .
Each range is controled by a NS5 screen connected in a LAN.
the FC51 are connected in an 2 wire MODBUS netwerk only using the connections 68 & 69.
this way I only have one Display prog .
1 short program that collects the message .
and 1 prog for the FC51 .
I can read the parameters 843.0 till 843.15 and write  the Data into the parameters 842.0 till 842.15 .
but i can not start or stop the inverter for there is no setting in 832.0 till 842.15 .
so how do I start and stop the inverter by Bus command..
I can send you the zip progs I am using if you like to have take a look at them
regards Johan
you need to write to register AF9 and you need to read register B5D those are the read and write starting control and status words.
To get the drive ready to run you need to operate coils: 2,3,4,5 and 10 to disable the brakes and stop commands and test coil hex 043c
you then operate coil 6 and the drive will run (hex 047c) , but you have not given it a reference using the second write control word AFA or select a preset reference via coils 0 or 1 and have a preset reference programmed in to the drive menu.
You really need to look at the section FC_port_ctw_1 and FC_port_ref_1 in my program it is very simple.
I'm not 100% sure the 51 and 280 are the same you may need to look into that but I know the 2800 fc280 and fc302 are the same.
