Posted 28 Nov 2016 Hello I am currently working on a system where we have multiple stations each comprising a Micro 850 and a PV800 HMI, the software on each is identical, the only difference being that the IP addresses will need to be different as they will all be on the same network for linking to a separate PLC. The plan is to have a PLC program with a default IP address that will be used to download to the PLC's, we would then use the Run Mode Configuration change to change the PLC's IP address , what I'd like to know, is there a way of changing The IP address for the controller in the PV800 in run time, or would the controller IP address have to be specified in the HMI before being down loaded? Regards. Share this post Link to post Share on other sites
Posted 1 Dec 2016 Please don't double post. People tend to not want to answer if you do that. Share this post Link to post Share on other sites
