Posted 19 May 2015 Hi all. I have a B&R PP420 panel, some I/O on the X2X and 4 Acopos servodrives /servomotors. Successfully created and tested 4 axes, they work OK, control via NCtest or X2X IN, or PP420 display. But creating CNC system is the problem... On NCtest, I have errors, and no move. Error 7742: ACP10_MC FB error or aborted Info: Axis Index [0] Info: ACP10_MC FB error number [29226] Info: Command aborted [0] Info: ACP10_MC FB number [1] = MC_BR_MoveCyclicPosition (cyc. pos.) On SDM, axis error: 32274 Network coupling: The broadcast channel was not configured Can someone help? Thanks.svinaga@yahoo.com Foto errors.pdf Share this post Link to post Share on other sites
Posted 31 May 2015 Hi, 1. try the signal Level on X1-Terminal / 24V/ and their parameter status 2. try with older Version of AS / for example V 2.7 / Vladimir, Sofia, Bulgaria thx80002002@yahoo.com Share this post Link to post Share on other sites
Posted 8 Jun 2015 Hi there, sorry no big help, can you consult the help system on it ? detailed info can be obtained from the FB MC_ReadAxisError(..). Maybe you can see what is the problem on the details. Also; the NC part seems to work as you inform, so you should check out the CNC configuration. BR BB Share this post Link to post Share on other sites
