Posted 4 May 2005 HELLO ALL I HAVE SETTING 136 ADDRESS IN THE PC WITH 0080 VALUE.ITS CHANGE EM IN MY PLC TO FILE MEMORY N NOW I CONFUSE HOW TO CHANGE FILE MEMORY TO EM AGAIN. I HAVE TRIED CHANGE THE PC SETUP ADRESS 136 WITH 0000 VALUE BUT I CAN'T ACESS EM ADRESS IN THE PC. HELP ME PLEASE REGARD Share this post Link to post Share on other sites
Posted 4 May 2005 Hello, If you're using CX-Programmer, open the PLC Settings component, under the CPU Settings tab, there is a checkbox for EM File setting enable. If you uncheck this, EM should once again become available once the Settings have been transfered to the PLC. By the way, it is a good idea to transfer Settings FROM the PLC, before downloading them TO the PLC. (I've screwed up many a Port setting this way ) Hope this helps anonymous Share this post Link to post Share on other sites
Posted 4 May 2005 ok thx alot mr.paul i've tried n success regard Share this post Link to post Share on other sites
