zsel
integrate balluff master module into Omron CX system
1 post in this topic
Hi, I'm new to the Omron PLC, we have a job that require we change the balluff master port from IO link to Stander IO output, i read some resource online saying that it has to be done though the cx configurator, i followed the instruction and tried to remove the module connection from the cx configurator and change the parameter and add it again. during this sequence i encounter some problem, the IO size for balluff master module is 392byte input and 262byte output, i've tried to add input though D17350 and output though D17550, i was only able to add one of them successfully, when going to the other one the softerware came  up with a error saying the it exceed the total tag size that the device supported, i tried to decrease the tag size but it would now match the device IO size when i tried to register it. all i need is to change the module's function from IO link to stander IO, hope someone has experience in these area can provide me some help
Thanks
