adi1612t1
Omron plc to Citect Scada communication
1 post in this topic
Hi Guys,
I need some suggestion & solution regarding my recent project.
The CQM1H plc which was used earlier is burnt and I am replacing it with CJ2M series Omron plc. Program transfer is possible from CQM1H to CJ2M. But the main issue is the system is controlled by Citect SCADA version 5.50 pack C. The communication of plc and Scada is through 2wire twisted pair cable. I just wanted to know when I replace the plc and convert the program do I have to change any settings or parameters in Scada? If I keep the same previous plc parameter in new plc and check the tags correctly in new plc as per old plc then the new system will communicate with Scada?
I am new to citect scada so please provide your support and help.
