Posted 17 Jul 2023 Hello! I'm currently using NB designer v1.531 (Build 210511) and I'm having compilation errors. It states: Connecting... Connection Error PT HMI0 Compilation error! Cannot create pkg files! I'm have trouble understanding, what does this error mean? I'm not connecting to any HMI, I just want to compile the program and test it offline. The weirdest thing is that if i click "Compile" enough times, it will eventually compile, but this is really interrupting the workflow. Does anybody else have this issue? Share this post Link to post Share on other sites
Posted 17 Jul 2023 Update: I think i found a similar issue and the fix also worked for me On 4/14/2021 at 11:41 AM, igarciap7 said: I know this is an old one but if somebody else gets this message, I realized that if you have your project in a folder which has a long folder path, NB crashes compiling and this error appears. The way I solved it is copying the project to the path that NB is installed and then you can compile it without any problem. Share this post Link to post Share on other sites
