Posted 11 Apr 2022 (edited) Hello everyone I'm new to omron plc . I have a system which consists 1. Omron Plc CP2E 2. Two stepper motors and their drivers. 3. 4 Inputs- one stepper start push button, second stepper go back push button, third stepper 1 home sensor, fourth stepper 2 home sensor 4. 4 Outputs- stepper 1 step(-) Q 100.00, stepper 1 dir(-) Q100. 02, stepper 2 step(-) Q100. 01, stepper 2 dir(-) Q100. 03 Seuence is like that:- Initially both stepper motors are at their home sensor. When start push button is pressed both stepper move 110 mm distance and then stop. Now when go back push button is pressed both stepper motors should go back to their home sensors and should stop at reaching their hone sensors. This is the sequence. Can someone please send me the program by writing in cx - programmer or upload the photos of ladder program and settings also. Please Edited 11 Apr 2022 by vipin Share this post Link to post Share on other sites
Posted 12 Apr 2022 hyee... do you already solve the problem I kind of have same problem with U but i using omron cp1e if u already solve it ... can U show me ur ladder diagram and ur wiring ?? Share this post Link to post Share on other sites
Posted 16 Apr 2022 (edited) No.. I didn't get the solution. If I get the solution I will post it here. And you can post if you get the solution before I get it. Edited 16 Apr 2022 by vipin Share this post Link to post Share on other sites
