Posted 8 Feb 2022 (edited) Hello friends, I am an Omron PLC user, but have never used modbus before. I have to connect an Omron CP1L-m to Beckhoff bk7300 via modbus serial gateway. 2-wire RS-485 connection (CP1W-CIF11). I have seen an easy to use Modbus RTU master for CP1L CP1H CJ1 CJ2 CS1 but the examples are not for dual port CP1L-m. If I change the PLC model "CP1HCP1LModbusDualPort" to "CP1L-M", the compiler tells me a lot of warnings about variable types. Is Modbus RTU Master easy to use for CP1L CP1H CJ1 CJ2 CS1 compatible with CP1L-M dual port (port 2)? I have tried to use it but it didn't work, error 02, illegal function code. Somebody could help me? Thank you Enric Edited 8 Feb 2022 by enric spelling errors Share this post Link to post Share on other sites
