Posted 13 Feb 2005 Do you have any reference about different types of actuator . I am a college student who doing reserach about this topic. cause I need to do a project for this topic. I need more information Share this post Link to post Share on other sites
Posted 13 Feb 2005 Do you have a project that needs actuators and you are looking for some help in that area or are you doing a research project on the different types of actuators? If you have a project already, tell us about it and I am sure you will get plenty of help. If this is a research project on all the different actuators out there, I would start by going to google and doing a search on actuators. Hope this helps, Bob O Share this post Link to post Share on other sites
Posted 5 Mar 2005 There's lots of types, as the above response mentioned, more detail would help get more help. Some basic actuators Electro-mechanical : An electro-magnet causes a magnetic object to move. (Exmaple - an electric buzzer door lock that is common to "Buzz" people into apartment buildings.) Pneumatic : An air pressure causes an object to move. Hydraulic : A liquid pressure causes an object to move. Thermal-Dynamic : A heat source or chilling source causes an object to expand or retract. (Example - a mercury switch that sits on a sprial spring in a thermostat. The sprial spring is the actuator) ---- There are also severl types of Physical actuators that can be used on limit switches. The actuators can be cam arms, roller arms, contact pressure, etc. Share this post Link to post Share on other sites
