Posted 1 Feb 2005 Hi I have alot of errors in my fault table, but i have no idea what it means or how to fix it.. any suggestion.. I have attached a pic of my fault table. It is also lightning a fault lamp on the plc, i guess it has some connection with the fault table? Is it possible to run a program even if i have these faults? I using a VersaMax PLC, with 1DI, 1DO, and 1AI module, and im almost sure this is set up correctly, i use the default setting on these modules.. Have anyone suggestions to my problems? Best Regards Share this post Link to post Share on other sites
Posted 1 Feb 2005 Found the problem, it was some hardware settings.. Share this post Link to post Share on other sites
