Posted 22 Dec 2017 Hi I got a easy one 4 you (I hope) In Tia Portal v13 i like to set op som grafiks on a KTP400 - I make 25 objects and group them to one, and do this 14 times(14 groups of 25 objects). Now i got 14 bits that I like to use to shift these groups from invisible to visible and back, i know i can do it on one objects at a time, buth can i do it to all 25 objects in the groupe in one go? /Sune Share this post Link to post Share on other sites
Posted 28 Dec 2017 That would be nice, but I haven't found such feature yet. When I'm in your position, I use a filled square or circle in background color to cover the "grouped" objects. Then change visibility for the square/circle Share this post Link to post Share on other sites
Posted 30 Dec 2017 1e You can do this very easy by working with layers. by enabling ore disabling layers you can switch tem on or off. I'm using it on a tp700 screen, and i thing this will work on a KTP400 as well. 2e solution is working with face-plates. with the the function visibility you can do the same with the whole group. Good Luck Tommy Share this post Link to post Share on other sites
