Posted 14 Feb 2017 dear friend i have problem about result digit number (plc & hmi show different) addres PLC & HMI its same,detail HMI : D0 show digit not stable D1 show 30.27 PLC: D0 show 4095 D1 show 3027 D0 (its not same) D1 (its same) please help me how to solve this problem ? im using mitsubishi FX1N (2 analog input) & HMI delta 7" thanks Share this post Link to post Share on other sites
Posted 14 Feb 2017 (edited) D8030 and D8031 are integer numbers. Try using EMOV D8030 D0. This should move them into D0 as floating point. Then you divide it by 100. EDIV D0 E100 Dxxxx. And you will have the same value as HMI stored in Dxxxx. I'm guessing that D8030 is an analogic value that is read by the PLC and you want to compare it with another one. Usually when you read a analog value it arrives without a point in the PLC (ex: 1234 in one of my applications is 123.4 degrees C.) To do operations with it you have to manipulate the value to be shown exactly like on the HMI. Edited 14 Feb 2017 by Andrei Blagaila Share this post Link to post Share on other sites
Posted 14 Feb 2017 dear andrei thanks for you comment,i was try,but result its same number in plc & hmi its not same,any way for solve ? thanks Share this post Link to post Share on other sites
Posted 15 Feb 2017 What value do you have set on the HMI to show? The HMI does the conversion automatically I think or I don't know. Bring up a photo of that window in the HMI project file to see it's settings. If you want to have the same number in the PLC in order to compare it you have to load the value as a float in a Word. So maybe add a Word. EMOV D0 Da EMOV D1 Db And then you divide them by 100: EDIV Da E100 Dx EDIV Db E100 Dy And you use Dx and Dy to compare values or to calculate differences or any other things. Dx and Dy are the values identical to the ones on the HMI Share this post Link to post Share on other sites
Posted 16 Feb 2017 you right,problem in setting my HMI ,im using doble word,after change to word,result its true (plc & hmi its view same value)thanks brother andrei problem was solve glad to know you Share this post Link to post Share on other sites
Posted 16 Feb 2017 You're welcome Glad to know you to. Share this post Link to post Share on other sites
