Posted 23 May 2016 HELLO EVERYONE, CURRENTLY I AM WORKING ON FX3U PLC. FOR MY PROJECT WE NEED 2 ANALOG OUTPUTS SO WE BOUGHT FX2N-2DA MODULE. I ALREADY READ THE MANUAL FOR FX2N-2DA PROGRAMMING BUT I DIDNT GET SATISFACTORY THING FROM THAT. PLEASE HELP ME IN THIS . JUST SHOW ME THE PROPER PROGRAMMING FOR FX2N-2DA MODULE FOR 0-10V DC. ANY SCREENSHOTS OR MANUAL OR ANYTHING. THANKS Share this post Link to post Share on other sites
Posted 26 May 2016 (edited) Here's the manual You'll find some examples in it What software and version are you using ? Edited 26 May 2016 by Bryll Share this post Link to post Share on other sites
Posted 26 May 2016 (edited) Thanks for the reply... I am using GXWorks2 version 1.87R I already read that manual but i am not able to understand the example given in that. Please if you have any another manual or example then send me.. thanks Edited 26 May 2016 by SHIV121 Share this post Link to post Share on other sites
Posted 26 May 2016 Attached is a Mitsubishi made FB for the FX2N-2DA unit. The FB is made in GX IEC Developer but should import to GX Works without any problem. This should hopefully solve your problem FX2N-2DA.zip Share this post Link to post Share on other sites
Posted 26 May 2016 Hey,,,, thanks Bryll for your support. But i also got the configuration of FX2N-2DA in ladder format also. And it looks easier. I will try both of it. Share this post Link to post Share on other sites
Posted 26 May 2016 The function block gives you everything you need, it's quite simple to use. "Special_Module_Position" - If this is the first unit to the right of the cpu, write 0, second unit = 1, and so on. "Analog_Value_Ch1" - Your analog value (0-4000) that represents the output of 0-10VDC at the output. "Analog_Value_Ch2" - Same as above, but for channel 2. "Module_In_Operation" - Don't think this one needs any explanation. Compile and download, but don't forget to give the block an instance. Share this post Link to post Share on other sites
