innoaloe
NS10 to CJ2M-CPU31 Ethernet/IP Problem
1 post in this topic
Hello, recently I tried to hook up a new CJ2M-CPU31 (built-in EIP Port) with a NS10-TV01-V2, which has an Ethernet/IP connection also. I made the simple setting as usual : 1. PLC, IP Address 192.168.250.1, Sub 255.255.255.0, FINS Node 1, no change to FINS/UDP parameter (Auto Dynamic Generation) 2. HMI, IP Address 192.168.250.2, Sub 255.255.255.0, FINS Node 2, Register the Host as EIP, SYSMAC-CJ2 mode with the PLC IP, Disables the Serial Port For some reason, there is no communication between NS and CJ2M (timeout error always occurs). I tried to re-register the Host as FINS, set the Node to 1, and also with no avail. I did try to connect the NS to a CP1L-EM with FINS Comm. and it works fine. Anything I did miss? Thanks in advance
