Vudv
How to control the value of I/O device Gimac_II by Vijeo Citect?
1 post in this topic
REGISTER - ADDRESS - REGISTER NAME 1 - 0 - CB ON select 2 - 1 - CB ON op 3 - 2 - CB OFF select 4 - 3 - CB OFF op 5 - 4 - DO1 ON select 6 - 5 - DO1 ON op 7 - 6 - DO1 OFF select 8 - 7 - DO1 OFF op 9 - 8 - DO2 ON select 10 - 9 - DO2 ON op 11 - 10 - DO2 OFF select 12 - 11 - DO2 OFF op 13 - 12 - DO3 ON select 14 - 13 - DO3 ON op 15 - 14 - DO3 OFF select 16 - 15 - DO3 OFF op 17 - 16 - DO4 ON select 18 - 17 - DO4 ON op 19 - 18 - DO4 OFF select 20 - 19 - DO4 OFF op 21 - 20 - DO5 ON select 22 - 21 - DO5 ON op 23 - 22 - DO5OFF select 24 - 23 - DO5 OFF op 25 - 24 - DO6 ON select 26 - 25 - DO6 ON op 27 - 26 - DO6 OFF select 28 - 27 - DO6 OFF op 29 - 28 - DO7 ON select 30 - 29 - DO7 ON op 31 - 30 - DO7 OFF select 32 - 31 - DO7 OFF op 33 - 32 - DO8 ON select 34 - 33 - DO8 ON op 35 - 34 - DO8 OFF select 36 - 35 - DO8 OFF op 1001 - 1000 - FAULT RESET 1002 - 1001 - EVENT clear 30001 - 0 - DI Status, DO Status 30003 - 2 - Equipment status, Reserved 30005 - 4 - Phase Current A 30007 - 6 - Phase Current B 30009 - 8 - Phase Current C 30011 - 10 - Phase voltage A-phase 30013 - 12 - Phase voltage B-phase 30015 - 14 - Phase voltage C-phase 30017 - 16 - Line-to-Line voltage AB-phase 30019 - 18 - Line-to-Line voltage BC-phase 30021 - 20 - Line-to-Line voltage CA-phase 30023 - 22 - Power Factor 30025 - 24 - Total of active power 30027 - 26 - Total of reactive power 30029 - 28 - Total of apparent power 30031 - 30 - Frequency 30033 - 32 - Total Active Energy 30035 - 34 - Total Reactive Energy 30037 - 36 - Total Reverse Active Energy 30039 - 38 - Zero-Phase Voltage 30047 - 46 - A[0] Current Value 30049 - 48 - A[1] Current Value 30051 - 50 - Positive Phase Voltage 30053 - 52 - Negative Phase Voltage 30055 - 54 - Voltage Unbalance Rate 30057 - 56 - Positive Phase Current 30059 - 58 - Negative Phase Current 30061 - 60 - Current Unbalance Rate 30063 - 62 - V0_max 30065 - 64 - Phase A Voltage Phase 30067 - 66 - Phase B Voltage Phase 30069 - 68 - Phase C Voltage Phase 30071 - 70 - Phase AB Voltage Phase 30073 - 72 - Phase BC Voltage Phase 30075 - 74 - Phase CA Voltage Phase 30077 - 76 - Phase A Current Phase 30079 - 78 - Phase B Current Phase 30081 - 80 - Phase C Current Phase 30083 - 82 - Phase A Power Factor 30085 - 84 - Phase B Power Factor 30087 - 86 - Phase C Power Factor 30089 - 88 - Phase A Active Power(Reverse Active Power) 30091 - 90 - Phase B Active Power(Reverse Active Power) 30093 - 92 - Phase C Active Power(Reverse Active Power) 30095 - 94 - Phase A Reactive Power 30097 - 96 - Phase B Reactive Power 30099 - 98 - Phase C Reactive Power 30101 - 100 - Phase A Apparent Power 30103 - 102 - Phase B Apparent Power 30105 - 104 - Phase C Apparent Power 30107 - 106 - Phase A Active Energy 30109 - 108 - Phase B Active Energy 30111 - 110 - Phase C Active Energy 30113 - 112 - Phase A Reactive Energy 30115 - 114 - Phase B Reactive Energy 30117 - 116 - Phase C Reactive Energy 30119 - 118 - Phase A Reverse active Energy 30121 - 120 - Phase B Reverse active Energy 30123 - 122 - Phase C Reverse active Energy 30125 - 124 - DEMAND Ia 30127 - 126 - DEMAND Ib 30129 - 128 - DEMAND Ic 30131 - 130 - Max DEMAND W 30133 - 132 - Max W 30135 - 134 - Phase Voltage A THD 30137 - 136 - Phase Voltage B THD 30139 - 138 - Phase Voltage C THD 30141 - 140 - Phase Current A THD 30143 - 142 - Phase Current B THD 30145 - 144 - Phase Current C THD 30147 - 146 - Phase Voltage AB THD 30149 - 148 - Phase Voltage BC THD 30151 - 150 - Phase Voltage CA THD 30153 - 152 - Phase Voltage A Basic Wave 30155 - 154 - Phase Voltage A 2Harmonic 30157 - 156 - Phase Voltage A 3Harmonic 30159 - 158 - Phase Voltage A 4Harmonic 30161 - 160 - Phase Voltage A 5Harmonic 30163 - 162 - Phase Voltage A 6Harmonic 30165 - 164 - Phase Voltage A 7Harmonic 30167 - 166 - Phase Voltage A 8Harmonic 30169 - 168 - Phase Voltage A 9Harmonic 30171 - 170 - Phase Voltage A 10Harmonic 30173 - 172 - Phase Voltage A 11Harmonic 30175 - 174 - Phase Voltage A 12Harmonic 30177 - 176 - Phase Voltage A 13Harmonic 30179 - 178 - Phase Voltage A 14Harmonic 30181 - 180 - Phase Voltage A 15Harmonic 30183 - 182 - Phase Voltage B Basic Wave 30185 - 184 - Phase Voltage B 2Harmonic 30187 - 186 - Phase Voltage B 3Harmonic 30189 - 188 - Phase Voltage B 4Harmonic 30191 - 190 - Phase Voltage B 5Harmonic 30193 - 192 - Phase Voltage B 6Harmonic 30195 - 194 - Phase Voltage B 7Harmonic 30197 - 196 - Phase Voltage B 8Harmonic 30199 - 198 - Phase Voltage B 9Harmonic 30201 - 200 - Phase Voltage B 10Harmonic 30203 - 202 - Phase Voltage B 11Harmonic 30205 - 204 - Phase Voltage B 12Harmonic 30207 - 206 - Phase Voltage B 13Harmonic 30209 - 208 - Phase Voltage B 14Harmonic 30211 - 210 - Phase Voltage B 15Harmonic 30213 - 212 - Phase Voltage C Basic Wave 30215 - 214 - Phase Voltage C 2Harmonic 30217 - 216 - Phase Voltage C 3Harmonic 30219 - 218 - Phase Voltage C 4Harmonic 30221 - 220 - Phase Voltage C 5Harmonic 30223 - 222 - Phase Voltage C 6Harmonic 30225 - 224 - Phase Voltage C 7Harmonic 30227 - 226 - Phase Voltage C 8Harmonic 30229 - 228 - Phase Voltage C 9Harmonic 30231 - 230 - Phase Voltage C 10Harmonic 30233 - 232 - Phase Voltage C 11Harmonic 30235 - 234 - Phase Voltage C 12Harmonic 30237 - 236 - Phase Voltage C 13Harmonic 30239 - 238 - Phase Voltage C 14Harmonic 30241 - 240 - Phase Voltage C 15Harmonic 30243 - 242 - Phase Current A Basic Wave 30245 - 244 - Phase Current A 2Harmonic 30247 - 246 - Phase Current A 3Harmonic 30249 - 248 - Phase Current A 4Harmonic 30251 - 250 - Phase Current A 5Harmonic 30253 - 252 - Phase Current A 6Harmonic 30255 - 254 - Phase Current A 7Harmonic 30257 - 256 - Phase Current A 8Harmonic 30259 - 258 - Phase Current A 9Harmonic 30261 - 260 - Phase Current A 10Harmonic 30263 - 262 - Phase Current A 11Harmonic 30265 - 264 - Phase Current A 12Harmonic 30267 - 266 - Phase Current A 13Harmonic 30269 - 268 - Phase Current A 14Harmonic 30271 - 270 - Phase Current A 15Harmonic 30273 - 272 - Phase Current B Basic Wave 30275 - 274 - Phase Current B 2Harmonic 30277 - 276 - Phase Current B 3Harmonic 30279 - 278 - Phase Current B 4Harmonic 30281 - 280 - Phase Current B 5Harmonic 30283 - 282 - Phase Current B 6Harmonic 30285 - 284 - Phase Current B 7Harmonic 30287 - 286 - Phase Current B 8Harmonic 30289 - 288 - Phase Current B 9Harmonic 30291 - 290 - Phase Current B 10Harmonic 30293 - 292 - Phase Current B 11Harmonic 30295 - 294 - Phase Current B 12Harmonic 30297 - 296 - Phase Current B 13Harmonic 30299 - 298 - Phase Current B 14Harmonic 30301 - 300 - Phase Current B 15Harmonic 30303 - 302 - Phase Current C Basic Wave 30305 - 304 - Phase Current C 2Harmonic 30307 - 306 - Phase Current C 3Harmonic 30309 - 308 - Phase Current C 4Harmonic 30311 - 310 - Phase Current C 5Harmonic 30313 - 312 - Phase Current C 6Harmonic 30315 - 314 - Phase Current C 7Harmonic 30317 - 316 - Phase Current C 8Harmonic 30319 - 318 - Phase Current C 9Harmonic 30321 - 320 - Phase Current C 10Harmonic 30323 - 322 - Phase Current C 11Harmonic 30325 - 324 - Phase Current C 12Harmonic 30327 - 326 - Phase Current C 13Harmonic 30329 - 328 - Phase Current C 14Harmonic 30331 - 330 - Phase Current C 15Harmonic 30333 - 332 - Phase Current A TDD 30335 - 334 - Phase Current B TDD 30337 - 336 - Phase Current C TDD 30339 - 338 - Phase Current A Kfactor 30341 - 340 - Phase Current B Kfactor 30343 - 342 - Phase Current C Kfactor 31004 - 1003 - Vo max time 31007 - 1006 - DEMAND Ia Time 31010 - 1009 - DEMAND Ib Time 31013 - 1012 - DEMAND Ic Time 31016 - 1015 - MAX DEMAND W time 31019 - 1018 - MAX W Time 40001 - 0 - PT Ratio Setting 40003 - 2 - GPT Ratio Setting 40501 - 500 - V0_MAX RESET V 40503 - 502 - DEMAND CURRENT RESET Newly added A 40505 - 504 - MAX DEMAND W RESET Newly added W 40507 - 506 - MAX W RESET Newly added W 40509 - 508 - WH RESET WH 40511 - 510 - VARH RESET VAR 40513 - 512 - rwh RESET WH 41001 - 1000 - Run Time 41003 - 1002 - CB ON Time 42001 - 2000 - Winding Method, Frequency Upstream(Winding Method),Downstream(Frequency) 42002 - 2001 - CT Ratio Setting 42027 - 2026 - DEMAND TIME(1/2/3/4/5/6/10/15/20/30/60 Min.) Per Minute 42029 - 2028 - DI 1 SET STATUS 0x5000?? Fix(Fault Type) 42030 - 2029 - DI 2 SET STATUS 0x5000?? Fix(Fault Type) 42031 - 2030 - DI 3 SET STATUS 0x5000?? Fix(Fault Type) 42032 - 2031 - DI 4 SET STATUS 0x5000?? Fix(Fault Type) 42033 - 2032 - DI 5 SET STATUS 0x5000?? Fix(Fault Type) 42034 - 2033 - DI 6 SET STATUS 0x5000?? Fix(Fault Type) 42035 - 2034 - DI 7 SET STATUS 0x5000?? Fix(Fault Type) 42036 - 2035 - DI 8 SET STATUS 0x5000?? Fix(Fault Type) 42037 - 2036 - DO 1 SET STATUS Refer to DO type 42038 - 2037 - DO 2 SET STATUS Refer to DO type 42039 - 2038 - DO 3 SET STATUS Refer to DO type 42040 - 2039 - DO 4 SET STATUS Refer to DO type 42041 - 2040 - DO 5 SET STATUS Refer to DO type 42042 - 2041 - DO 6 SET STATUS Refer to DO type 42043 - 2042 - DO 7 SET STATUS Refer to DO type 42044 - 2043 - DO 8 SET STATUS Refer to DO type 43001 - 3000 - CB OPERATION COUNT 0~232 -1 43003 - 3002 - DO01 OPERATION COUNT 0~232 -1 43005 - 3004 - DO02 OPERATION COUNT 0~232 -1 43007 - 3006 - DO03 OPERATION COUNT 0~232 -1 43009 - 3008 - DO04 OPERATION COUNT 0~232 -1 43011 - 3010 - DO05 OPERATION COUNT 0~232 -1 43013 - 3012 - DO06 OPERATION COUNT 0~232 -1 43015 - 3014 - DO07 OPERATION COUNT 0~232 -1 43017 - 3016 - DO08 OPERATION COUNT 0~232 -1 I-NET Interface Section 43041 - 3040 - I-Net Information Refer to F038_2 44001 - 4000 - Event Record 46001 - 6000 - TimeSync How to control the CB at the address I / O from 1 to 36. with the example code below? FUNCTION Confirm_CB(STRING sel,STRING op) TagWrite(sel,0xFF00); Sleep(2); TagWrite(op,0xFF00); END INT FUNCTION ReadTagBit(INT Tag, INT Bit) INT TagVal, Power; Power = Pow(2, Bit); IF Tag BITAND Power THEN TagVal = 1; ELSE TagVal = 0; END RETURN TagVal; END FUNCTION CBStatus() Gipam_CB_On = ReadTagBit(Gipam_Status,0); Gipam_CB_Off = ReadTagBit(Gipam_Status,1); Gimac_CB_On = ReadTagBit(Gimac_Status,7); Gimac_CB_Off = ReadTagBit(Gimac_Status,6); END Please help me, sincerely to thank! Manual_102_104.pdf Edited by Vudv
