Posted 29 Jan 2008 I occasionally get a major fault on my ML1000 for no apparent reason (I am thinking it may be a line noise issue). Anyway I want to automatically clear the fault on bootup, so I have set bit S:1/8 to 1 (override at powerup). Fault bits are cleared except for S:5/8 (Retentitive Data Lost) which always gets set with S:6 bits, except I don't see a way to clear S:5/8 at powerup, I must manually go into RSLogix to clear it.S:1/8 says it clears minor error bits S:5/0 - S:5/7 and major bit S:1/13, but I am still hung up with S:5/8 being on. Any ideas? Share this post Link to post Share on other sites
Posted 30 Jan 2008 Clear the bit you need to clear in the fault routine, this routine is scanned when a fault occur. By default is routine #3 but you can change it with S:29 (see picture) micro1000_program_files_description.pdf Share this post Link to post Share on other sites
