Posted 18 Oct 2007 Is there another method of communicating to this controller other than the 1761-CBL-PM02 cable? I have the 1784-PCMK card, 1784-PCM cable with 1784-CP7 adapter, plus various serial cables. I also have a 1747-UIC convertor. One would think that A-B would enable the 1784-CP7 to be compatible with the ML 1200. Oh I forgot, this is A-B I'm talking about. Share this post Link to post Share on other sites
Posted 18 Oct 2007 If you have a DH485 network set up (with 1761-NET-AICs), you could use a PCMK w/ a PCM4 cable and/or a 1747-UIC to communicate on that network. Otherwise you have to use the direct serial connection. Yeah, A-B hasn't been entirely dis-ambiguous in their use of comm. connectors over the years. I wouldn't disagree with you if you said it was frustrating and confusing. Share this post Link to post Share on other sites
Posted 18 Oct 2007 Thanks for the information. I thought this was the only option but just wanted to be sure. Share this post Link to post Share on other sites
Posted 18 Oct 2007 actually if you really wanted to get fancy you could attach a 1761-NET-ENI and use ethernet, but those are a bit pricey Share this post Link to post Share on other sites
